large files not fully transferred
gracelim
Re: large files not fully transferred
Post by gracelim »
sftp
gracelim
Post by gracelim »
sftp
BestSync SFTP supports uploading/downloading huge files that are larger than 4TB.
Please check if your SFTP server supports handling huge files.
gracelim
Post by gracelim »
we use sftp.
after upgrade of bestsync from 2019 to 2020. we still encounter files not being fully sometimes.
gracelim
Post by gracelim »
the largest file we ever send is only 13 mb. it is sometimes not getting transfer fully.
is it possible that the file generation is not yet finished but bestsync is already sending the file to the target server might cause the problem?
gracelim
Post by gracelim »
any help is greatly appreciated..
We have used BestSync to synchronize huge files (mores than 4TB) with SFTP (Cerberus FTP server) by SFTP protocol, all worked fine.
Please try the BestSync 2020 (VER 15.0.0.21) to see if it works with your SFTP Server.
