Editing task files
Re: Editing task files
But re-sizing the column has to be performed every time the main window is opened; this display setting is not saved with the Task File or with general options. So changing column width every time (and on all three tabs) is a workaround, not a fix. BestSync 2011 displayed the check-boxes without the Task Overview and this was saved under Option > Option > View.
