Uploading a 6.3 GB file to Amazon S3 always fail
Re: Uploading a 6.3 GB file to Amazon S3 always fail
We have found and fixed a bug that may crash the program.
Please uinstall the old version, and try the follwoing new version:
32Bit version:
http://www.risefly.com/2013/BestSyncSetup.msi
64Bit version:
http://www.risefly.com/2013/BestSyncSetupX64.msi
denovo
Post by denovo »
I installed the new version and it is being working for two days without crashing and running more than 10 tasks as a service.
Thanks,
David
denovo
Post by denovo »
I was using the beta version you offered for several months, until I needed to change the configuration. Now I can not save changes to the task list. I noticed that it was reported as a known bug in "BestSync won't save project-file" and it was solved in 3.1.75.
What can I do?
is this S3 feature already merged in BestSync 2012?
David
Thank you for the report, we are developing BestSync 2013, and will test this issue before release it.
