ZIP functionality
tjblow
ZIP functionality
Post by tjblow »
I am trying to use the ZIP functionality in BESTSYNC 2015. Not Sure if I am using this correctly. If folder1 contains files I want to copy to another folder and zip them in folder2 two is this the correct process? Local data volume as Folder1 and ZIP type of connection to local folder2.
Or is this for moving a zip file form folder1 to folder2 as a zip folder and updating folder2.? The help documentation is a little brief on this functionality.
Thanks for the Support.
-- Tim
Re: ZIP functionality
The ZIP-Sync feature is used to synchronize (ZIP) Folder1 to an Archive File (Folder2). From the second time of the synchronization, BestSync only ZIPs changed files to the ZIP archive file.
Could you please describle wha tkind of error or problem that you met when use the ZIP-sync feature?
Best regards
