When I try to transfer the multiple large files from local drive to distination server through sftp. There is always a problem with incomplete file transfer. e.g. When I copy 7 files to the sftp server, there is always 3 / 4 files transferred with incomplete in tern of total size and cannot be opened (attached). Referring to the log, it said the file is completely transferred.
May I know how why?
Large file transfer
Large file transfer
- Capture.PNG (23.58 KiB) Viewed 6502 times
Re: Large file transfer
Could you please export the task setting to a file then send to risefly@risefly.com? So that we can debug and find the cause of the problem/
