Adding license to BestSync 2011
tames
Post by tames »
Can I add additional license to BestSync 2011 or do I have to upgrade to BestSync 2015 and then add license.
Re: Adding license to BestSync 2011
If you want to use BestSync 2011, you can order the license of BestSync 2015, the license code should work on BestSync 2011.
But I strong recommend you to use BestSync 2015.
