BestSync consumes all memory
saghir
Post by saghir »
I recently upgraded to BestSync 10.0.4.X and have the software setup to sun as a Service that synchronizes 3 network folders with the local computer on which BestSync is installed.
I have noticed that about every 3 weeks, BestSync consumes all the memory and the system slows down (disk/memory swaps). The problem is fixed by restarting BestSync. Previously I was running version 8.0.5.0.0 (on one machine) and 7.3.1.2 (on another machine) and I did not see this problem.
Any help would be appreciated.
Re: BestSync consumes all memory
BestSync needs the memory to manage the file data, if there are too many folders/files under the synchronized folders, BestSync may use large memory. If the folders are too large, please setup multiple tasks in BestSync, each task synchronizes a sub-folder.
