encryption viruses Protection
zeus1976
Post by zeus1976 »
Good day,
In recent months, there are more and more encryption viruses, which encrypt all data (without the consent of the user)
Now it would be great if BestSync would check with each sync, how much of the data set has edged up.
If the record has changed more than 20% (variable), no Synchronisation is done, so we were protected from such situations and the data would not be overwritten (with encrypted data - Virus)
Is it possible at BestSync?
Thank you for your feedback.
Best regards
Re: encryption viruses Protection
I'm sorry that BestSync has not this kind of function.
It is better that you use anti-virus software to detect the viruses then remove them.
