Startup at windows logon
michael.mbx
Post by michael.mbx »
Dear,
On startup with windows (10) the sync app won't startup in the system tray. I have done what on the forum is mentioned. Run as administrator, toggle option to ' start at windows logon' off and on, but with no result. I have always to start bestsync manually. How to solve the problem?
I have had it befor in windows 8, but after reinstalling it was solved. However, i reinstalled with the latest version, and no result. In taskmanager i see bestsync service is running. (only 1 entry in taskmanager)
Re: Startup at windows logon
I have tested BestSync under Windows 10, it started BestSync without problem.
You can open the "Task Scheduler" of Windows 10, find Task "StartBestSync", you can adjust the settings to ensure Windows Start BestSync.
