I will use BestSync to sync a local folder to google drive. I use 15gb free account on google drive and i have to delete old files like 20 days old on google drive side.
I am trying BestSync on my local folders for now and i have following settings to delete target folder side but it doesn't work.
how can i do it?
Thank you.
[attachment=0]bestsync.png[/attachment]
Delte files older than issue
- bestsync.png (24.1 KiB) Viewed 10813 times
Re: Delte files older than issue
You can try the following option to delete files that are older than 20 days in the target folder (Google Drive).
[attachment=0]DeleteOld.png[/attachment]
- Delete Old Files
- DeleteOld.png (25.45 KiB) Viewed 10807 times
As your screen capture i have successfully synced my folder but i realized that it is still not working with google drive.
Is there any other options to choose for working with Google Drive?
Thank you.
Thank you.
Please try the new version 11.0.0.4 to see if the problem can be resolved.
