Except for one thing...suddenly these two lines are gone...
And I cannot figure out how they could be re-enabled.
I guess this i simple, and it COULD have something to do with another task I have installed, the "TuneUp Utilities" from AVG.
I'm in the process to get rid of that, as my Windows Security backup has gone to the movies, as well as the update function.
But if you know a enable disable switch of the context menu list, I would be grateful. It could help me in this troubleshooting.
Thank you! And thanks for a very good app!
Best regards,
Lars
