I'd like to group several tasks and set up the group as one item to be triggered by time scheduler. Once triggered the tasks should be accomplished sequentially and not in parallel.
How can I achieve this?
With regards,
Lukasz Szamota
Task grouping
Re: Task grouping
You can use the "Application"/"Application or Sync-Task to run after synchronization" to run task one-by-one after a main task:
[attachment=0]AppID.png[/attachment]
- Application TaskID
- AppID.png (15.2 KiB) Viewed 8761 times
