SFTP Error: WriteFileBytes Must First Connect to SSH Server???
netfidelis
Post by netfidelis »
I am randomly getting this error when transfering multiple files. This (and similar) errors occur on about 12-15% of files transfered, the rest transfer just fine (507 Success 78 failed). They are all of similar size. This just recently started occuring. I have upgraded to the latest version of Bit Sync to no avail. I have attached a screenshot of some of the errors showing up.
Re: SFTP Error: WriteFileBytes Must First Connect to SSH Server???
It will be helpful if you can export the task setting to a file, then send it to risefly(a)risefly.com.
So we can find what causes the error.
