Upgraded to Bestsync 2016 11.0.1.0 now process speed at a crawl
After installing the upgrade my sync process speeds have dropped to nearly zero KB per second. The highest speeds I have receive is .12kb/s averaging .05kb/s which is pretty much zero. Any ideas as to why this would happen? I always seem to have major issues after every upgrade.
Re: Upgraded to Bestsync 2016 11.0.1.0 now process speed at a crawl
What kind of file system does the task synchronize with?
Having the same problem with 2 Windows 10 PCs, just bought Bestsync Premium. Sync one way from PC1 to PC2. After first sync I deleted a number of files (including zip-files) on PC1 and started sync again. Process is very slow (see attachments).
Thanks for help.[attachment=1]160912_BestSync_Snapshot1.png[/attachment][attachment=0]160912_BestSync_Snapshot2.png[/attachment]
- 160912_BestSync_Snapshot1.png (6.26 KiB) Viewed 10323 times
- 160912_BestSync_Snapshot2.png (15.21 KiB) Viewed 10323 times
In the preview, it shows that there are 3.646GB file need to be deleted, because the task has setup a backup option, these 3.646GB files also need to be backup to the backup folder. Because the files are in a network shared folder, I think it may take long time to complete the task.
