Upgrading to 2016
nicholasg86
Upgrading to 2016
Post by nicholasg86 »
Hello, do you have a document on how to upgrade to 2016? Currently using 2014 Ultimate and don't know if I should un-install first?
Re: Upgrading to 2016
Though the installer of BestSync 2016 will uninstall old version automatically, It is recommended that you uninstall the old version first, then install the new version.
BestSync will convert the task settings of old versions such as BestSync 2015, 2014,2013 etc automatically, after install the new version, all the task settings will be loaded.
The license of two versions before will be down-graded on BestSync 2016. If you want to use the same license type on BestSync 2016, please order the upgrade license from the following page:
http://risefly.com/upgrade.htm
