fail to view log after job successful
desmondchen
Post by desmondchen »
Dear Sir
I can't figure out. why does some job can "view log" then some job can't?
pls somebody help me.
Version:11.0.1.1
os:2008 R2 x64
Re: fail to view log after job successful
Please enable log options in the "Log" settings of the task.
Check the "Record the log data for the log view window.".
desmondchen
Thank you for your reply.
I have enabled "Log" option of the task, but the status same as before.
Enable two option:
1. Record the log data for the log view windows
2. Export log data to following files:
The log will be recorded if some files are copied, or error happens.
Please try to change a file, then run the sync-task. The log must be recorded.
