Bestsync 2016 fails to minimize on Windows start
laxity
Post by laxity »
I am running Bestsync Ver11.0.1.2(64Bit) on Windows 10. In general options I have ticked the following :
Start bestsync when windows starts (ticked)
Start as a tray task icon (ticked)
When Windows boots Bestsync always opens the main window on login/startup and doesn't minimize to the tray for some reason.
How do I get it to start in the task tray on boot?
Many thanks,
Richard.
Re: Bestsync 2016 fails to minimize on Windows start
Please try the following steps to see if the problem can be resolved.
1. Open the "General" options.
2. Un-Tick "Start as a tray task icon".
3. Press "OK" to close the dialog box.
4. Open the "General" options again.
5. Tick "Start as a tray task icon".
6. Press "OK" to close the dialog box.
laxity
Post by laxity »
Tried your suggestion but unfortunately it didn't work.
Please try to exist BestSync, then run it as administrator.
Then do the above action (the last suggestion) once again.
laxity
Post by laxity »
Ok that fixed the issue thanks.
I selected properties on the bestsync.exe and selected the "run as administrator" option. That seemed to sort the issue.
