Delete on two way sync
robbieger
Post by robbieger »
Hi There
Delete on two way sync is not working with NAS source and target.
If I delete a file on one side (target or source) it syncs back, instead of deleting on the other side.
It works as expected when I use local folders on the server, but not with UNC source and target.
I have upgraded to Ver 11.0.1.3
thank you
Re: Delete on two way sync
Because the synchronization action depends on the timestamp of files, if the time difference between the system time of the local PC and NAS is larger than 30 seconds, then the synchronization action may not be correctly.
Please check if the system time of your NAS device is correct.
