Windows 10 Version 1607 - Win32 long paths
ms5joseph
Post by ms5joseph »
The latest build of Windows 10 released yesterday includes a setting for Win32 long paths. I was wondering if this is on the roadmap for BestSync to support?
Enabling Win32 long paths will allow manifested win32 applications and Windows Store applications to access paths beyond the normal 260 character limit per node on file systems that support it. Enabling this setting will cause the long paths to be accessible within the process.
Re: Windows 10 Version 1607 - Win32 long paths
BestSync has already supported the long path up to 32767 characters if the file system is NTFS.
