RIsefly,
I'm trying to sync a folder by using *.png. If there are other files that are .png in folder 2, Bestsync will delete them.
Do I have to exclude each extension(.png) that is not in folder 1? If not what do I need to do?
Is this normal for any sync task that uses a " *.extension" to sync?
Thank you.
Re: Sync file *.png
If you only want to sync some file types, please use the "Filter by file types" of the "Filter" tab.
Do not use *.extension in the folder name.
