All task missing after reboot
CurtisZM
Post by CurtisZM »
TO All,
Lately I've noticed sometimes when I reboot BestSync is missing all my schedule task. How can I fix that? Thank you.
Running: English Version Ver12.0.0.5(64Bit)
Re: All task missing after reboot
This may be the privilege problem. Windows has prohibited BestSync from saving the task profile.
Please try to start BestSync by Administrator privilege once, and try to check the options as the attached screenshot by "Options/Options" menu.[attachment=0]StratOption.png[/attachment]
Start Options
Start Options
CurtisZM
Post by CurtisZM »
Risefly,
That is what it has been set in the beginning when I installed BestSync.
OS: Windows 10
May be BestSync has no right to write the task setting to the current setting folder,
please try to use "File"/"Save as" menu to save the task profile to a different folder.
