Throttle or Run After Hours
networkthiniking
Post by networkthiniking »
Any way to setup to run after hours or throttle the bandwidth?
Wally
networkthiniking
Re: Throttle or Run After Hours
Nevermind, I found a way to schedule after hours. It would be great if you can control bandwidth of the sync...
If the task is synchronizing with FTP, WebDAV or cloud storage, there is a tab to control the network bandwidth; Other file systems can not use the bandwidth control.
