Sync does not end.
djffnrejffnr
Sync does not end.
Post by djffnrejffnr »
You are using the FTP protocol to synchronize.
It's okay when I first sync.
However, the problem occurs from the second automatic synchronization.
Monitoring... (Notified:3403, Queued:7)
Progress Bar 100.00%
Time:Remain[72:00:00] , Used[1:46:51]
This state persists.
When I look at realtimeview, the file is OK every 5 seconds.
This is much slower than the first synchronization.
At this time, if a file change occurs
File synchronization does not work properly.
What setup should I do?
Re: Sync does not end.
FTP protocol uses a different port each time when it connects to the FTP server as the data channel,
this action may be blocked by (Windows) Firewall if you have not set the firewall correctly.
For how to set the firewall and the task for FTP synchronization, please refer to the following page:
http://www.risefly.com/fseqna_ftp.htm#ftp_firewall
Please ensure that the task is not blocked by (Windows) Firewall.
