File Path Too Long
whisperinghill
File Path Too Long
Post by whisperinghill »
I have several files that won't sync because the file path is too long. Error Code 553. Is there a way to override the length with out changing the file names?
I also want to let you know, beetween this software and FileApp for iPad, I can now synchroinise my working files folders./ Obviously with the issue noted abovbe as an exception
Bud
Re: File Path Too Long
Please try to uncheck the following option to see if the issuse can be avoided:
Uncheck "Use intermediate file during copy..." option of the "Copy options" setting page.
whisperinghill
Cool, that did the trick, :D thanks for the response.
I guess now I need to determine if I need the other options, probably do and buy a license
