Onedrive Shared folder Conflict
vziogas
Post by vziogas »
i need to sync an onedrive personal account with a desktop folder.
Everything works fine except the folders that others share with me.
In these folders, i can only download files and changes. when bestsync tries to sync (upload) my local files to the cloud i get a 409 conflict result.
How can i fix this problem?
Thanks in advance!
Re: Onedrive Shared folder Conflict
Could you please post the log at the bottom of the preview of the task here?
vziogas
Post by vziogas »
>POST /oauth20_token.srf
<200 OK
>GET /me/skydrive/files?limit=100&filter=folders
<200 OK
>GET /folder.5bae28a00542229e.F02B1E3CE55AC8E!4478
<200 OK
>GET /folder.5bae28a00542229e.F02B1E3CE55AC8E!4478/files?limit=100
<200 OK
>[1]POST /oauth20_token.srf
<[1]200 OK
>[1]GET /me/skydrive/files?limit=100&filter=folders
<[1]200 OK
Download file failed, can not find the file id.
>[1]GET /file.5bae28a00542229e.F02B1E3CE55AC8E!4479
>[2]POST /oauth20_token.srf
<[1]200 OK
<[2]200 OK
>[2]GET /me/skydrive/files?limit=100&filter=folders
<[2]200 OK
>[3]POST /oauth20_token.srf
<[3]200 OK
>[3]GET /me/skydrive/files?limit=100&filter=folders
<[3]200 OK
>[4]POST /oauth20_token.srf
<[4]200 OK
>[4]GET /me/skydrive/files?limit=100&filter=folders
<[4]200 OK
>[5]POST /oauth20_token.srf
<[5]200 OK
>[5]GET /me/skydrive/files?limit=100&filter=folders
<[5]200 OK
>[6]POST /oauth20_token.srf
<[6]200 OK
>[6]GET /me/skydrive/files?limit=100&filter=folders
<[6]200 OK
>[7]POST /oauth20_token.srf
<[7]200 OK
>[7]GET /me/skydrive/files?limit=100&filter=folders
<[7]200 OK
>[2]GET /file.5bae28a00542229e.F02B1E3CE55AC8E!5116
>[3]GET /file.5bae28a00542229e.F02B1E3CE55AC8E!5788
>[7]GET /file.5bae28a00542229e.F02B1E3CE55AC8E!5779
<[2]200 OK
<[3]200 OK
<[7]200 OK
vziogas
Post by vziogas »
And here is the log after the synchronization
(there are 3 files not synchronized from my desktop to my onedrive shared (from others) folder)
<200 OK
<200 OK
<200 OK
<200 OK
<[1]200 OK
<[1]200 OK
<[1]200 OK
<[2]200 OK
<[2]200 OK
<[3]200 OK
<[3]200 OK
<[4]200 OK
<[4]200 OK
<[5]200 OK
<[5]200 OK
<[6]200 OK
<[6]200 OK
<[7]200 OK
<[7]200 OK
<[2]200 OK
<[3]200 OK
<[7]200 OK
<200 OK
>[2]Upload /Last test viz/proxiro koufomata.pdf
>[2]PUT /folder.5bae28a00542229e.F02B1E3CE55AC8E!4478/files/proxiro%20koufomata.pdf
>[3]Upload /Last test viz/samsonite.txt
>[3]PUT /folder.5bae28a00542229e.F02B1E3CE55AC8E!4478/files/samsonite.txt
>[1]Upload /Last test viz/Memo Style Train.pdf
>[1]PUT /folder.5bae28a00542229e.F02B1E3CE55AC8E!4478/files/Memo%20Style%20Train.pdf
[2]409 Conflict
[2]Conflict
[3]409 Conflict
[3]Conflict
[1]409 Conflict
[1]Conflict
[3]409 Conflict
[3]Conflict
[1]409 Conflict
[1]Conflict
[2]409 Conflict
[2]Conflict
[3]409 Conflict
[3]Conflict
[1]409 Conflict
[1]Conflict
[2]409 Conflict
[2]Conflict
Saving the meta data.
>Upload /Last test viz/_BestSync_Meta.dat_
>PUT /folder.5bae28a00542229e.F02B1E3CE55AC8E!4478/files/_BestSync_Meta.dat_
409 Conflict
Conflict
Please confirm from the owner of the shared the folder to see if you have the writing privilege to the shared folder.
vziogas
Post by vziogas »
I confirm that i have the writing (edit) privilege of the shared folder.
i can see it in the onedrive online platform, the owner also confirmed and when i change things or upload sth to this folder using the online onedrive platform it works.
I'm regret to tell you that BestSync does not support synchronizing with shared folders of others now.
As alternative way, please synchronize with your folders and share them instead.
vziogas
Post by vziogas »
Thank you for the information.
Hope you can add it to the next update!
Branders
Post by Branders »
Anyone know if it will be added in the next update?
