BestSync doesn't open Dropbox
Barnabas
Post by Barnabas »
Dear BestSync support!
I have a problem connecting to Dropbox. Until the end of august, I could upload to Dropbox via Bestsync. From then, I can't log into Dropbox in Bestsync, it doesn't list the folders. Last week I purchased and upgraded bestsync to the latest version and it still doesn't work.
I have the latest updates on Windows 7.
Here is a video of the problem:
https://www.dropbox.com/s/09rwdn5hciif5 ... x.mp4?dl=0
Please, suggest a solution asap.
Thanks!
Re: BestSync doesn't open Dropbox
Please try BestSync 2018 (VER 13.0.0.4) to see if the problem can be resolved.
Barnabas
Post by Barnabas »
I updated to the latest version, it still doesn't work. I installed BestSync to another computer and tried with a different dropbox account, the same problem occurs there as well.
Does Your version work with dropbox?
BestSync 2018 VER 13.0.0.5 has fixed the problem, please download and try the new version to see if the problem is fixed.
Barnabas
Post by Barnabas »
Dear BestSync Support!
Thanks for the quick help, this function is now working perfectly!
Have a good day!
