Can't install Bestsync
mguterman
Post by mguterman »
I need to install Bestsync 2012 after unistalling.
I have error "The installer was interrupted before BestSync could be installed. You need to restart the installer to try again"
I have tryed to use Administrator install but is still doesn't work.
OS is Windows Server 2012 R2 Standard
Re: Can't install Bestsync
Because BestSync 2012 is a very old version, it is not guaranteed to run on the new OS, and the version is out of supported now.
Please try the newest version (BestSync 2018).
