BestSync log showing that file sync was successful but its not
jimmar
Post by jimmar »
I am syncing multiple files ranging from 5bytes to atmost 200gb to my Amazon S3 account, all files except (90gb file is the closest one before this) for one single 200gb file is being synced successfully however on the Log View Windows BestSync is showing that it is a success. I have checked Amazon S3 for any possible issues with files not showing up but I have found nothing. Have you guys encountered anything like this? What can you recommend for me to get this fixed? Thanks
Re: BestSync log showing that file sync was successful but its not
We have tested upload huge files to S3 by our account, all worked fine.
Please check your task setting to confirm where have the task uploaded files.
