Betsyncdecrypt on android mobile
Eric
Post by Eric »
I would like to decrypt with my android device encrypted files that I have saved on Amazon Drive.
Do you have an app/android version of Bestsyncdecrypt for Android? What is the possibility because standard apps on Android that usually decrypt AES256 files do not work with ones encrypted by Bestsync?
many thanks
Re: Betsyncdecrypt on android mobile
There is not an android application for decrypting files that is encrypted by BestSync.
