update and migrate BestSync
LouisV
Post by LouisV »
My organisation is currently running BestSync 2014 on a Win2008 server. We like to move to a Win2016 server and update to BestSync 2019. Is there an easy way to do this without having to reconfigure a new installation and manually recreating all jobs?
Re: update and migrate BestSync
You can just download and install BestSync 2019.
All the task settings will be inherited from the old version.
If the old setting are not loaded in by the new version, you can find the settings from the setting folder, then open the setting from the new version.
The setting folder is described in the following page:
http://www.risefly.com/help/logfile.htm
