BestSync redundancy
LouisV
BestSync redundancy
Post by LouisV »
My organisation is more and more dependant of BestSync. Is there a way to make it operate redundant? For example to run it on a Windows cluster or by automatically sync the config and jobs to a second BestSync server?
Re: BestSync redundancy
BestSync setting files are described in the following page:
http://www.risefly.com/help/logfile.htm
You can synchronize the setting files (.xfsf) by BestSync.
But the current version of BestSync will not restart after the setting file is changed outside.
