Hello
I an synchronizing on GC using encryption and it works well. However, I have files like music or videos that once synchronized are systematically re checked (using the preview windows) and re synchronized, even if by definition there has been no changes between my PC and Cloud version on such files. it is very cumbersome because each synchronization takes a very long time, although the changes I have performed since previsous sync are pretty small.
can you help in finding the right parameters in Bestsync to avoid this issue?
many thanks
Synchronization on Google Cloud
Re: Synchronization on Google Cloud
Could you please capture the task setting screens then send them to risefly@risefly.com, so that we can give you more advice.
