Filezilla FTP Server with TLS certificate
staun
Post by staun »
Did anyone get this product to work with Filezilla FTP-Server using a certificate on the FTP-server.
I can get it working with plain FTP port 21, but as soon I use a certificate for secure on the FTP-server (port 990 - TLS implicit), transfers I get various errors, sometimes it connects, other times I get TimeOut on login etc....
I have no firewall, no antivirus between my to test computers which is located on same network.
I get errors like this.
FTP HELP: Try to add 'C:\Program Files\RiseFly\BestSync\BestSyncApp.exe' to the allowed program list of Windows Firewall or other antivirus software.
FTP HELP: Try to add port 58972 to the allowed sending port list of Windows Firewall or other antivirus software.
Failed to connect the data port.
other times (when login timeout)
>USER 000filesync
SSL:Receive::DecryptMessage.(0x80090330):The specified data could not be decrypted.
when I get a connection through the synchro somestimes work - folders are sync. but not files. Other times only one way
Re: Filezilla FTP Server with TLS certificate
Is it possible that you send a test account of the FTP server to risefly@risefly.com? so that we can debug with the FTP server.
staun
Post by staun »
Test-Account sent to your mail.
