view log shows incorrect date
gracelim
Post by gracelim »
hi,
wondering why bestsync show incorrect time (time that task got executed) in view log .
in the sample screenshot, it show the task was run at 08:00, but the file is created on 09:03:29.
bestsync version :14.0.1.6
gracelim
Re: view log shows incorrect date
Post by gracelim »
was i able to upload the screen shot of the view log?
gracelim
Post by gracelim »
gracelim
Post by gracelim »
the task 's schedule is set to realtime sync: synchronize file immediately after files are changed.
Because real-mode task never end, the log file is saved periodically, so the time stamp of the log may be much newer than the started time of the task.
gracelim
Post by gracelim »
the file w/ created 9:03am is the file to be transfer not the log file. the log file is 8am .
based on what you said , then the logfile should be >= 9:03am ,right?
sanaviroham
Contact:
Post by sanaviroham »
Great Share!! :)
