Cannot Sync when Run as a Service is Enabled
dave_ames
Post by dave_ames »
I am able to set up a sync job that works when run manually or scheduled.
When i set the job to run as a service, and then test it by running manually, the job fails with the message: Encrypt<==>Decrypt.
Can anyone tell me what i can do about this.
Re: Cannot Sync when Run as a Service is Enabled
If a task fails when run as Windows Service, please refer to the following Q&A:
http://www.risefly.com/fseqna.htm#DriveNotReady
dave_ames
Post by dave_ames »
thank you
i have tried your advice with no success.
the error message i am getting is 'Encrypt<==>Decrypt' not "drive is not ready'.
Do you know what i can do about this problem: 'Encrypt<==>Decrypt'
thank you
Could you please tell me which version are you using?
