Bestsync 2013 Process Terminates after launch
rastamanx
Post by rastamanx »
Hi there. I've been running BestSync 2013 for many years, but recently, the executable program always terminates about 10 seconds after being launched. This happens on my Windows 7 and Windows 10 systems. Tried uninstalling and re-installing program. When i run windows task manager, and launch bestsync.exe, i can see program process starting, and then it automatically stops and disappears from task manager. Not sure why this is doing this. Any help/advice greatly appreciated. Thanks!
Re: Bestsync 2013 Process Terminates after launch
I noticed that you are using the very old version. BestSync has been improved very much from your old version. I recommend you to upgrade to the newest version as soon as possible for protecting you data and having a better experience.
Please confirm it the problem exist on the newest version.
