Pause sync
bazzano
Pause sync
Post by bazzano »
Hello.
Is there any way to pause a sync task (and resume later)?
I have sync tasks with tons of files and sometimes I need to temporarily suspend them. I don't want to make a full scan anytime they restart.
Is there a way to pause them, instead of stopping them?
Thank you.
Roberto
Re: Pause sync
If you start the sync by preview, then you can start and stop (pause) the synchronization.
Otherwise, you can not pause the synchronization.
bazzano
Re: Pause sync
Post by bazzano »
Tried and it works, thank you.
Anyway it's a sort of a workaround, I would suggest to add a button "pause/resume" and "pause/resume all tasks" in the main toolbar.
Thank you.
Roberto
