Wrong total space?
bazzano
Wrong total space?
Post by bazzano »
Hello.
The image at the following url is an extract of the bottom preview window.
How is it possible that "Spazio Completati" (completed space) is bigger than "Spazio Totale" (total space) ?
Is there a bug with decimals, or measure units?
If after the dot there are decimals than "Spazio Totale" (total space) should be 4.376 TB (and not GB).
http://www.z80ne.com/temp/image1.jpg
Thank you.
Roberto
Re: Wrong total space?
Could you please tell me what version are you using now?
If the task is set to run in real-time mode, this status is possible because task never end and same file may be synchronized multiple times in the running period.
bazzano
Post by bazzano »
Hello.
I'm using the version Ver15.0.0.4(64Bit)
The task is set to run as a service, but this is the first syncronization pass (there are 4 TB to sync and it takes alot).
Also it's a consolidated storage disk, and files are not changing.
Is it correct "4.376 GB" as shown? As told, there are around 4 TB to sync.
Thank you.
Roberto
We have confirmed that this is a bug, TB is displayed as GB by mistake.
Please download the new installer to fix this problem.
bazzano
Post by bazzano »
Great!
Thank you.
Roberto
