Move files to a folder according to Month?
edbc080
Post by edbc080 »
Hello, I would like to know if BestSync is capable of moving files from Folder 1 to sub-folders (named January , February, etc) in Folder 2 according to the month of when the file was uploaded to Folder 1.
This way when BestSync moves the files from Folder 1 to Folder 2 they are moved to the corresponding sub-folder by month .
Is this possible?
Thanks for your help.
Re: Move files to a folder according to Month?
Yes, if you want to move files from Folder1 to Folder2, you can set the folders like the following:
Folder1: C:\Folder1\
Folder2: C:\Folder2\<Date:yyyy-MMMM>\
Here is the help document:
http://www.risefly.com/help/TimeFormat.htm
