BestSync does not auto-start
Since the upgrade of BestSync to version 2021, the autostart of the program no longer works when Windows starts (Ver16.0.1.2 (64Bit)).
Re: BestSync does not auto-start
Please confirm in the Windows "Task Scheduler" to see if the " StartBestSync" Task is set correctly as the following screenshots.
"Task Scheduler" is in the Administrative Tools of Control Panel.
- StartBestSync Setting1
- StartBestSy6nc1.png (42.62 KiB) Viewed 44197 times
- StartBestSync Setting2
- StartBestSy6nc2.png (16.83 KiB) Viewed 44197 times
- StartBestSync Setting3
- StartBestSy6nc3.png (12.45 KiB) Viewed 44197 times
The problem may be caused by Windows update and antivirus software. Please try following steps to see if the problem can be resolved.
(1)Exit BestSync Application.
(2)Stop antivirus software.
(3)Start BestSync Application by "Run as administrator" context menu of the BestSync desktop icon.
(4)Open the option menu, uncheck the auto-start settings, close the dialogbox.
(5)Open the option menu again, check the auto-start settings like the following, close the dialogbox.
- StartBestSy6nc4.png (13.53 KiB) Viewed 44196 times
