550 SSL/TLS Error
550 SSL/TLS Error
I just upgraded from a very old version (2011) of BestSync to the latest version. One of my FTP connections stopped working after the upgrade. I've attached the message that I am receiving. Files are sent to a server owned by a local IT guy. I don't think that there is any kind of formal certificate for the site. How do I get this issue resolved? Thank you.
- Untitled.jpg (192.46 KiB) Viewed 21693 times
Re: 550 SSL/TLS Error
The error from the FTP server says that it need the TLS/SSL to connect to the FTP server.
Please try to select [Implicit TLS/SSL] or [Explicit TLS/SSL] option to see if the error can be resolved.
Here is what I get when I try that solution:
- explicit-error.jpg (187.48 KiB) Viewed 21687 times
- implicit-error.jpg (190.58 KiB) Viewed 21687 times
Please confirm whether the FTP port is 990 or something else.
I was able to get this resolved with the correct settings from my local developer. I appreciate your feedback.
