Open File from preview window
David.P
Post by David.P »
Can it be that this is actually not possible?
Because then that would, unfortunately, disqualify Bestsync for me. I believe it is an indispensable feature to be able to take a quick look into a file to be synced.
David
Re: Open File from preview window
If the file can be opened by a local tools (application), in the Preview, you can use the "Explorer Folder X" context menu to open the file.
Drake
Contact:
Post by Drake »
Indeed, if the file can be opened locally by an application, using the "Explore folder X" context menu in the preview is an excellent method of quickly accessing the file. This simplifies navigation and makes file access smoother. Thanks for sharing this handy tip with us!
