SFTP File Transfer
les.billings
SFTP File Transfer
Post by les.billings »
I am trying to create a transfer from a folder to an external openssh server.
when i try and create "folder 2", i can fill in the details including adding the private key in advanced settings.
every time it tries to connect it says that i have to initialize SFTP, but i don't know where to do this.
the documentation only describes FTP and not SFTP.
any help would be much appreciated.
Les
using BestSync 2023 latest version
Re: SFTP File Transfer
Here is the step about how to set up the SFTP synchronization task.
https://www.bestsync.us/SyncSFTP_howto.htm
You can start the preview of the task to see if there is any error log at the bottom of the preview window.
