hi,
i noticed that when we do view logs, log is empty for all the task. but in reality there are activities going on even service.log do not records any activities. Its been running for more than 1 week . see attached file.
have installed the bestsync under a different user account (not Administrator account)
bestync version: 2024 19.0.0.1 64bit
windows : 2019 std
pls advise how can we resolve this.
thanks
bestsync not logging
bestsync nologs1.docx- (192.39 KiB) Downloaded 1295 times
bestsync nologs2.docx- (235.66 KiB) Downloaded 1372 times
bestsync nologs3.docx- (192.61 KiB) Downloaded 1337 times
Re: bestsync not logging
hi, im also seeing lots application sid does not match conductor id in event viewer. dont know if this has something to do with the issue
Application 'C:\Program Files\RiseFly\BestSync\BestSyncApp.exe' (pid 2752) cannot be restarted - Application SID does not match Conductor SID..
I can see that no TaskList.fsl has been created.
Please try to save the task list to another folder by "File"/"Save as" menu to see if the problem can be resolved.
right now, there are entries when i view the log of each task.
but service.log , the entries are these (see belosw). is this normal in previous version all transfer made are also listed here?
so i tried your suggestion to go to file menu save as in different folder (d:\log\bestsync).
but only 3 files got created tasklist with the ff:extensions xfsf,fss,xresult. no file fsl is created
2024/01/14-21:11:59,***** BestSync start ****
OS Version:Windows Server 2012 Standard Edition, 64-bit (build 9200)
BestSync Version:
2024/01/14-21:11:59,BestSyncApp.exe
2024/01/14-21:11:07,***** BestSync start ****
BestSync Version:
2024/01/14-21:11:07,BestSyncApp.exe /trayicon
2024/01/22-08:47:04,Start Service, 0
2024/01/22-10:06:48,***** BestSync start ****
BestSync Version:
2024/01/22-10:06:48,BestSyncApp.exe
2024/01/25-11:49:56,***** BestSync start ****
BestSync Version:
2024/01/25-11:49:56,BestSyncApp.exe
2024/01/25-11:50:42,Start Service, 0
2024/01/25-14:25:03,***** BestSync start ****
BestSync Version:
2024/01/25-14:25:03,BestSyncApp.exe
2024/01/25-11:50:42,An instance of the service is already running.
2024/01/25-14:26:02,Start Service, 0
2024/01/25-14:26:02,Cannot create a file when that file already exists.
2024/02/02-23:32:01,***** BestSync start ****
BestSync Version:
2024/02/02-23:32:01,BestSyncApp.exe /trayicon
BestSync Version:
BestSync Version:
BestSync Version:
BestSync Version:
BestSync Version:
BestSync Version:
If the tasks are "Run as Service", the log file are saved in "C:\ProgramData\RiseFly\BestSync", please check if there is service.fsl in the folder.
If BestSync can not save log to the file, you can try to delete the file to let BestSync create it again.
