Scheduling does not work
yairp
Post by yairp »
I bought a Premium license but the Windowws Service is not working. The schedule is to run a task every night but it does not run!
It was working fine in the past
It also says that this function is limited.
I need a solution ASAP
Re: Scheduling does not work
If you need to run the task by Windows Service, you need the Business License or above.
Please order the upgrade license from the following page:
http://www.risefly.com/upgrade.htm
yairp
Post by yairp »
It ued to run as a windows service when I had the basic licence.
Now I need to pay another 32$ after paying $22 for something that worked?? Thanks but no thanks
