Calendar Sync: Is It Really That Simple?
Sam574
Post by Sam574 »
Hey folks,
So, syncing calendars... it's supposed to be easy, right? But we all know it can turn into a bit of a headache when you’re juggling between different platforms, especially if you need real-time updates. I’ve been playing around with some tools, and I noticed syncing across multiple devices still leaves room for weird delays or missed events. Anyone else notice that?
Do you guys have any tricks or specific setups that make it run smoother? I’m curious if there's a way to optimize the process without running into those occasional sync glitches. What’s the best combo of services you’re using that works consistently?
Would love to hear your thoughts!
Re: Calendar Sync: Is It Really That Simple?
You can consider letting Google Calendar, Microsoft Outlook, etc online service or flow API do the synchronization task.
