How to migrate to a new server w/BEstSync 2022 to 2025
copyfiles
Post by copyfiles »
I have 2022 BestSync on an older server "A".
I setup a new Server "B" with BestSync 2025.
How do I migrate from the older 2022 installation on server A to BestSync 2025 on Server B?
I tried copying the entire RISEFLY folder and doing an upgrade on the folder, nothing shows up for our configured tasks and Services on Server B.
Re: How to migrate to a new server w/BEstSync 2022 to 2025
Thank you for reaching out to us with your query regarding exporting tasks and configurations from a 2022 BestSync client and importing them to a 2025 client on a different server.
To export all the tasks and configurations, you need to locate the task setting file from your 2022 BestSync client. Here are the steps to follow:
1. **Locate the Task Setting File**: The task setting file is typically stored in the BestSync installation directory. The default path is usually:
<SystemDrive[C:]>\Users\<User>\AppData\Roaming\RiseFly\BestSync[Version]\
Replace `<User>` with your actual Windows username and `[Version]` with the version number of BestSync you are using.
2. **Copy the Task Setting File**: Once you have located the task setting file, copy it to the new server where the 2025 BestSync client is installed.
3. **Import the Task Setting File**: On the new server with the BestSync 2025, start BestSync and open the task settings from the [File] menu. This should restore all your tasks and configurations. Please note that folder paths in sync-tasks may differ on the new PC compared to the old PC, so you will need to modify the paths before starting the sync-tasks.
4. If you want to migrate the tasks that run as Windows Service, the setting file is here:
<SystemDrive[C:]>\ProgramData\RiseFly\BestSync[Version]\Service.xfsf
You need to copy the service.xfsf to <SystemDrive[C:]>\ProgramData\RiseFly\BestSync2025\Service.xfsf of the new PC.
