saving the same config on multiple computers
JCDinPGH
Post by JCDinPGH »
We recently became a licensed business user and we have about 50 workstations that all need a one way sync to a folder on a server. The server folder will always be the source. Is there an easy way to save/export the settings from one workstation install and then load/import those into another workstation install to avoid having to go through all of the options when doing a new install? since we have to install on 50 different workstations, it could be quite time consuming. FWIW, all of the setups will be identical including the local folders and userids/passwords.
Thanks.
Re: saving the same config on multiple computers
You can try to use the deployment tool of BestSync:
http://www.risefly.com/deploytool.htm
Use the tool, you can do following jobs:
(1) Install/Uninstall BestSync in silent mode
(2) Start/Stop BestSync Application.
(3) Start/Stop BestSync Service.
(4) Deploy BestSync project file
(5) Activate License.
(6) Copy program files.
