Question about USB sync
ttom
Post by ttom »
In the answer to the question of "How does BestSync synchronize two computers by an USB drive?" in the Q&A page of the website, it is said that "BestSync flush the drive to ensure all the files have written out". How is this done? What settings shall I use to get this function? My USB drive is getting full now - this function will be really help.
Thanks!
Re: Question about USB sync
You need not to do any setting. BestSync flushs the removable drive after the synchronization.
You can just take out the removable drive after the synchronization.
ttom
Post by ttom »
Well, that was not the case for me. I used two-way synchronization for the direction on both the computers to be synced. In the filter settings I choose to sync files changed in the last 30 days as the folder size is much larger than the size of the USB drive if this option is not selected. The size of the folder just keeps increasing and files copied to the USB drive never got deleted..
I looked at the "Delete" options but that doesn't help..
Though time range filter setting is selected, but if the files out of the range already exist, BestSync will not delete these files automatically.
This setting is only for improving the sync speed, not for increasing the capacity.
You can try the "Delete the unchanged files in the target folder" in the "Delete" setting page for synchronizing files with samll capacity USB drive.
ttom
Post by ttom »
The "Delete the unchanged files in the target folder" in the "Delete" setting page is grayed out and cannot be selected somehow..
The "Delete the unchanged files in the target folder" option is disabled if the following options are select:
1. Bi-direction synchronization is selected in the “Task Wizard: General” page.
2. Real-Time monitoring option is selected in the “Task Wizard: Schedule” page.
3. "Copy to a single folder" is checked in the “Task Wizard: Rename” page.
ttom
Post by ttom »
That means I cannot do a bi-directional sync...?
You can do "bi-direction" synchronization, but if bi-direction sync is selected, you can not select "Delete the unchanged files in the target folder". Because if bi-direction is selected, "Delete the unchanged files..." will cause the unchanged files be deleted from the both side, that will cause file lost obviously.
