Downloaded .txt file removes the formatting
Hi, when the downloading was done, then I opened the .txt file, the formating was removed but when I open the file from the server, the formatting was still there (spaces,line break ect.). Do you have a fix for this?
Re: Downloaded .txt file removes the formatting
If you are using the "ASCII Mode" of the FTP option, BestSync will convert the carriage-return code from "\r\n" to "\n", this seems that the format of .txt file has been removed.
Please select the "Binary Mode" in the FTP options of the "General" property Page of the task, this issue can be avoided.
